Check Coolant but tank full
Old Mar 21, 2018 | 06:10 PM
Gsonia's Avatar
2002 Mercedes C320
Mercedez C320 red warning on dash reading turn off engine with temp showing off the grid! I check the tank to fill with coolant but it is full!
I started car to try to make it home and temp is constantly going up and down.
Old Mar 21, 2018 | 07:14 PM
tjts1's Avatar
C320
Is your cooling fan functioning?
Old Mar 22, 2018 | 03:58 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Is the coolant temperature sensor working? Easiest way to tell is to turn the key to position 2 in the morning when the engine is cold.
Old Mar 23, 2018 | 06:07 PM
Gsonia's Avatar
2002 Mercedes C320
Fans are working perfectly fine I can hear them kick on when its supposed to. Just changed thermostat and not getting red warning anymore but temp on dash is fluctuating when driving through street but seems to stay a little above 80 while on freeway. Think there might be air? hoe do I get air out?
Old Mar 23, 2018 | 06:11 PM
tjts1's Avatar
C320
W203 should only have 1 fan.
Old Mar 24, 2018 | 12:42 AM
slammer111's Avatar
Any bubbles in the system get worked out fairly quickly under normal operation. They end up in the expansion tank, which then can be topped up as needed. Since you say your coolant level is at the correct height, this is probably not the problem.
Did you replace the coolant temperature sensor (the thing that provides the temperature reading in your dash), or the coolant thermostat (the valve that opens at 90C)? Just want to ensure we're talking about the same things.
Sounds like your temperature sensor has gone bad, but you may want to look into the thermostat if the temperature sensor has already been replaced.
Old Mar 27, 2018 | 03:57 PM
Gsonia's Avatar
2002 Mercedes C320
Thermostat was changed a few days ago and message went away for about a day then came back up. I’ve had temp checked with Infrared laser temp gun and temp is at about 100. I’ll shut car off and won’t use for hours at a time but as soon as I start engine red light starts flashing on dash and fan kicks on full speed.
Also, when I open tank to check coolant level there is a lot of pressure.
Old Mar 27, 2018 | 04:50 PM
tjts1's Avatar
C320
Is your water pump working properly? Take off the belt and spin it by hand. You also might have a blown head gasket.
Old Mar 27, 2018 | 07:41 PM
Gsonia's Avatar
2002 Mercedes C320
How and what am I looking for when spinning belt?
Old Mar 27, 2018 | 07:50 PM
tjts1's Avatar
C320
Yes, also is the belt loose? You can also remove the belt and spin the water pump by hand. Does it spin freely, any weird noises or binding. Should be a pretty easy DIY check.
