Coolant thermostat replacement
Old Mar 25, 2018 | 06:31 PM
Jess0815's Avatar
C300 sport
Cool Coolant thermostat replacement
I just changed my thermostat today on my 2009 c300. However my check engine light is still on. Do I have to drive for X amount of miles in order for this to go away, or what is the process? Help, I have to get tags in a few days 🤦*♀️
Old Mar 26, 2018 | 05:12 PM
RWDlifer's Avatar
2005 C230K SS
What CEL did you have to begin with? The thermostat by itself will not cause a CEL, if it fails it will stay open and the engine will run cooler. Your CEL is likely to be emissions related.
Old Mar 27, 2018 | 08:26 AM
Jess0815's Avatar
C300 sport
It was P0128. I knew it was the thermostat though because I'm a little ocd and watch my dash at all times and the temp wasn't running at its norm. Sure enough the old thermostat was wide open. The CEL has since went away after changing the thermostat
Old Mar 27, 2018 | 01:07 PM
tjts1's Avatar
C320
A bad thermostat absolutely will cause a CEL. Even in the older w203 if the engine never reaches proper operating temp or even if it takes too long to reach operating temp, it will trigger the cell.
