3.0 c280 engine work as a swap in a c230 sport?
Old Apr 4, 2018 | 04:41 AM
Dylan Drago's Avatar
C230 sport
Question 3.0 c280 engine work as a swap in a c230 sport?
Does anyone know if a 3.0 c280 engine is the same as the 2.5 in a c230? looks exactly the same, and is in the same size car, I'm assuming that its just stroked differently to be a 3.0. if engine is the same length and trans bolts are in the same place should be a easy swap.
Old Apr 5, 2018 | 03:46 PM
Nektopoli's Avatar
W203 & W204 3.0L 4matics & MR2 Supercharger
If it's the M272 then the block is the same, but it's longer stroke
https://en.wikipedia.org/wiki/Mercedes-Benz_M272_engine
NP
Old Apr 5, 2018 | 03:47 PM
Nektopoli's Avatar
Oh and you might want to run the engine number to make sure you don't have a bad balance shaft.
NP
Old May 9, 2018 | 04:31 PM
leeroytandy's Avatar
clk350 out,02 C270 CDI current 07 A170 out, Ml320cdi out!! GL 350 CDI, What a car !!!!!!
You might want to either re programme you ecu or get another ecu , to match the extra capacity , or you might not get the best out of the new engine
Old May 15, 2018 | 08:46 PM
W203E35's Avatar
2006 C350 Sport 6MT
It's a direct fit..someone who has access to Mercedes Xentry/DAS will need to change the coding mostly in developer mode. You don't need a new ECU.
What is Developer Mode Extension for DAS.
Developer extension of the DAS for Mercedes-Benz vehicles allows in-depth configuration and programming of the control units. This option is typically enabled for the factory version of the scanner. It was meant for development and testing purposes of the onboard electronic systems. It will allow the user to change the configuration of the car. For example, you can change the ECU, program to use a different engine model, change the speed limit or torque settings and a lot more. Using Developer Mode without knowing exactly what you are doing can be dangerous.
Here is the tool
http://www.mercedesmedic.com/das-xen...esources-wiki/
