Poor acceleration when engine reaches operating temp.
Old Apr 9, 2018 | 02:15 PM
Andy@work's Avatar
C240
My 2004 C240 has very poor acceleration when it reaches operating temp. I have checked the MAF, replaced fuel pump and filter, checked plug wires and coils but bo joy so far. Anybody have any suggestion on what to check next
Old Apr 9, 2018 | 07:58 PM
tjts1's Avatar
C320
Is your check engine light on? Is your MAF elbow fully seated?
Old Apr 21, 2018 | 05:22 PM
Andy@work's Avatar
C240
Hi. Thanks for your reply. I have checked the MAF elbow and all seems ok. No check engine light on. I think he problem could possibly be lack of fuel due to low feul pressure or the fuel filter that I have replaced not to long ago is sub standard. Any info on the correct fuel pressure will be appreciated. Also what is the possibility of a clogged cat? Could a clogged cat cause poor acceleration. Also the engine stutters and slightly backfires when the accelerator pedal is pressed quickly.
Looking forward to some possible causes.
Cheers for now
Old Apr 21, 2018 | 05:36 PM
tjts1's Avatar
C320
Fuel pressure should be around 53-56psi at all times including idle. It shouldn't drop when you rev the engine.
Old Apr 22, 2018 | 05:20 PM
Russell Ormerod's Avatar
not a merc
Explain what "I checked the Maf" means exactly?
