Scantool Question
Old Jun 1, 2004 | 05:14 PM
jim628's Avatar
Scantool Question
Hi:
Does anybody know of a good scantool that works for MB? Correct me if I am wrong, W203 is an OBDII compliant car.
Old Jun 1, 2004 | 06:52 PM
levelr123g's Avatar
i have this scan tool.
www.obd2.com
Old Jun 1, 2004 | 10:33 PM
Buellwinkle's Avatar
And I have this one and it works with MB and any other car I tried it with. Not every scanner works with MB, ask before buying. OBD 2 is a standard but different manufacturers have different protocols.
www.obd-2.com
Old Jun 1, 2004 | 10:37 PM
VirtueTek's Avatar
Looks very cool!
Are there base stats for "factory" w203's so you can compare stats?
I'm a newb here...so can you give me an example as to how this tool has helped you?
Old Jun 1, 2004 | 11:30 PM
I've used it to view and reset codes on several cars. I use it to look at what's going after putting a mod on (air filter, pulley, muffler, intercooler, etc). Since it works on all my cars, it easily will pay for itself over time.
Old Mar 19, 2012 | 12:18 PM
vjsilva's Avatar
C300 4MATIC Sport 2010
I have a 2003 C240 w/ 6 speed and I picked up the Innova equus 3130 Scantool based on this recommendation:
https://mbworld.org/forums/off-topic...scan-tool.html
The Equus 3130 is no better than any other scantool, maybe worse. It links with my car and 2 seconds later it says link lost. The unit does not support USB and cannot be upgraded over a serial port.
Can anybody recommend a good unit that works well with Mercedes cars?
Thanks,
Victor
Old Mar 19, 2012 | 07:04 PM
Glyn M Ruck's Avatar
Super Moderator
The 3130 can be updated.
If you want USB compatibility you need the 3130b
"Unit can be USB(cable included) flash updated with a standard Windows® PC (OBD-PC Link™ software required / included with tool)"
It is one of the most popular scanners on this board.
Let me tell you a secret. Most scanners use the same guts from one plant in Taiwan. They then get cases & Branding as requested.
