HELP!!!!-01 CLK 320 malfunction lights on
HI GANG
my 2001 CLK320 all of a sudden started flashing up car has 4 malfunctions and listed the below 3:
- BAS - brake assist
-ESP- elec.stab.prog.
-ABS system
they do not show up when starting the car until u touch the brake pedal.
I connected my scan gauge but it will / does not read any codes
brakes seem to be working fine
your help PLEASE!!!!
-ABS system
I’ve had this issue a few times in the past on my 210 and 208s. The culprit is your Brake Stop Light Switch, it sits on top of the brake pedal. Cheap part and takes about 20-30 min to replace. When you replace it the codes will clear automatically.
GL.
GL.
