Need help no power going on fuse 57 and 31 key won't turn
Old Oct 3, 2018 | 07:34 AM
Joaosoares's Avatar
I own a c230 kompressor 2004 and C300 4matic 2011
Hi everyone I one a c230 kompressor 2004 m271 my key isn't turn fuse 31 blow replace now I don't get power on fuse 31 and fuse 57 engine compartment somebody know if goes in another protection before there ?thanks everybody
Old Oct 5, 2018 | 09:47 AM
Joaosoares's Avatar
Please I gotta the car stuck
Old Nov 8, 2022 | 09:50 PM
MFH22's Avatar
W203 m111 c200k
Hi, did u fix the problem? I just had fuse 31 blown too
Old Nov 8, 2022 | 11:21 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Fuse 31 is starter/EIS (the module that handshakes with the key) related. Can you turn the key? Is there a clicking noise? Does the starter crank?
Old Nov 8, 2022 | 11:29 PM
MFH22's Avatar
W203 m111 c200k
refer to my fuse diagram, Fuse 31- EIS [EZS] control unit ,Electric steering lock control unit,
(i replaced the blown fuse 31)
My key won't turn, and i dont hear the ESL unlock
Old Nov 8, 2022 | 11:32 PM
slammer111's Avatar
Not sure what would make the fuse 31 blow. As in there's no reason why the EIS would every draw too much current under normal operation.
Unfortunately I think the EIS is car (VIN) specific. As in I'm not sure if you can even replace this with one from a wrecker.
Unless someone else here knows more about the module, you may be looking at the dealership.
Old Nov 11, 2022 | 02:08 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
I have seen somewhere on the internet, where people are able to swap the
chips containing the vehicle specific data to another EIS without the dealer.
Youtube maybe?
Old Nov 13, 2022 | 09:27 AM
tkid's Avatar
C230K M271 CL203 2003 model
EIS internal connector- known fault - soldering fails and the board connector drops off and moves around inside EIS,. i am guessing there might be potential for the metal parts of the connector to short out other parts of the circuit?, and cause the fuse to fail??
There are procedures here on other threads for the removal and repair of the EIS..
Old Dec 12, 2022 | 12:37 AM
MFH22's Avatar
W203 m111 c200k
Problem solved
1) Sent the EIS & ESL (need to send the complete steering column with the ESL attached)
2) EIS repaired
3) ESL was confirmed mulfunction
4) Tested pair EIS with 'ESL bypass emulator' - result ok
Decided to use 'ESL bypass emulator' instead replace the ESL
