ABS connect CLIP what is it called
What is the name of the part AKA plastic piece that you have to lift up to remove he connector from the ABS module ?
The clip broke so Now cannot separate the connect fort he abs module or reconnect it later.. you pull it up to remove down to connect.
Did you try eBay?
I'd just contact a seller of an ABS pump/module and ask them to list it separately...
https://www.ebay.com/itm/Mercedes-W2...2:pf:0&vxp=mtr
Thank you thank you for that info unfortunately he wants 30.00 for it ..I just need the clip . If the wire ends were longer I would have offered 20.00....
I'd just look for another seller.
It took me a few tries before someone would sell me the OEM clips/harness ends to the HVAC controller when I added Solar and Multi-function Sensors...
But it worked out. Just copy/paste and send some messages...
