Is this even possible? 28 codes runs great '05 C350 Lx
Old Oct 29, 2018 | 06:34 PM
n2zcars's Avatar
1992 500E, 2004 SLK32 AMG, 2006 C350L
I have been asked to look at my insurance agent's C350 since I drive the same car and opened my big mouth.
There are 28, YES 28 codes stored and it idles like a kitten and while not a spunky s mine it was very responsive,
I cleared the codes and after 30 minutes of driving therewas no CEL light and It was settling down from having brain salad surgury (clearing codes)
Without posting all of the (I'm lazy) 28 pics or typing out all of them, these are the first few: OK all of them
The first few codes were marked Pending and repeated as confirmed
P2257,
P0414
P0458
P9448
P2009
P0031, 51,37,57,
P2257
P0414
1066-00
1077-00
1074-00
0850-00
0958-00
1186-00
0442-00
0446-00
0426-00
0430-00
I have a call into Lucifer but he's just laughing...
Could someone shed some light ???
It did have a delco battery installed and a cam sensor replaced in the last year..
Thx in advance
Old Oct 30, 2018 | 01:45 PM
n2zcars's Avatar
edited by OP
Old Oct 30, 2018 | 05:48 PM
n2zcars's Avatar
I drove the car today, checked codes twice, looked at a live data streams and also followed some hints I read here. Here is what I know:
After clearing codes and pulling the gas cap, with no sound of air movement. The car drove the same as before clearing the 18 codes (which is actually 9)...
After driving 10 miles, stopping and idling for several minutes I notices one small misfire and the RPM rose and lowered and then all was smooth again.
Upon going to the NIKE store, for some political statement shoes, I started it up and within 10 seconds light was back on.
I drove 5 miles (smooth as normal) and tested with the same 9 codes in response. Checking the gas cap with 30% fuel still no air movement.
I saw the purge system was siting at 0% the O2 (all 4) were at ..4V and .45 volts and stuck there and the cats were in the 560-570 degree range. I glanced at temp numbers and some other things and deduced this thing must be in a form of limp in mode. When I was setting up to look at the live data, I again got a misfire and a slight rpm adjustment, not a search
I have been lucky in my other MB's as I have never had any serious issues that were drivability issues with them ( wiring harnesses, head gaskets yes!!!) but have been around lots of drivability issues with domestic and Asian cars in the 2000's through 2010 era but never something quite like this.
Am I heading in the right direction to pull the rear wheel well and inspect and be prepared to pay for a smoke test (or sacrifice a Churchill) to try and find the leak???
Codes in order in last 2 scans
P0448
P2009
P2257,
P0037
P0458
P0057
P0414
P0031,
P0051
Old Oct 30, 2018 | 09:12 PM
mtnman82's Avatar
'16 E350, gone: '03 c230k
Have you searched on the forum and seen the threads on replacing the fuel filler assembly? I threw a P0456, went through a lot of trial and tribulation and in the end replaced the pricey filler neck assembly all has been good. On that front anyway (knock on wood).
Old Oct 30, 2018 | 10:14 PM
n2zcars's Avatar
Yes new part number but still concerned as to why a fuel filler pipe can shut the system down and call out the O2's.
Old Oct 30, 2018 | 10:32 PM
ItalianJoe1's Avatar
2003 CL 600
A stuck open purge valve will cause rich conditions along with evap faults, are the fuel trims actually out? Sounds like your O2 values are normal, but that doesn't mean much by itself.
Old Oct 31, 2018 | 04:56 AM
n2zcars's Avatar
The O2s are fixed and not fluctuating >.4V and purge was at ZERO and I never saw move.
I cannot recall fuel trim numbers.
Old Oct 31, 2018 | 02:46 PM
n2zcars's Avatar
Yes, I read about the re engineered emissions (cough) part with no TSB or recall.....
Old Nov 1, 2018 | 05:03 PM
mtnman82's Avatar
Just wanting to ensure you were aware of the fuel filler issue on these cars. A leak in the system might possibly cause the computer to think there is an issue in the purge valve circuit. Then again, if that were the case I would expect it to be throwing the P0456 code too...
A lot of work for a vehicle that's not yours, and not sure the location is the same, but on my '03 c230 the purge valve is near the filler neck in the wheel well (have to remove the fender liner). If I recall correctly I took mine out, or maybe just grounded the correct side of the connection, to verify the operation of the valve. I think I had to do this when I ran a smoke test - making sure the valve was closed.
Good luck with it!
Old Nov 1, 2018 | 08:56 PM
n2zcars's Avatar
I think I am going to buy it, or I would have stopped as soon as the P2009 code was explained. I was amazed that there are lots of "C class" cars that are cheap because of these issues.I just think a cheap Twin might be fun and if it runs good, I may give it to daughter.
I am trying to figure out what wood to use for the smoke test Apple, Cherry or a mix...
Did you DIY the smoke test? Method used? Blowing cigar smoke in the gas tank just doesn't seem to be viable and I haven't priced it at local shops. I believe you were right on grounding to test, and to replace the seal when there.
Good luck with it!
Old Nov 3, 2018 | 05:22 PM
mtnman82's Avatar
I found a 'home made' smoke tester on eBay, similar to this if not the exact one (I paid at least $30 more at the time):
https://www.ebay.com/itm/EVAP-Smoke-...53.m1438.l2649
It uses mineral oil to produce the smoke. The only bummer is that the 'wick' they use tends to burn and needs to be replaced (supposedly can find them at Walmart for cheap).
Old Nov 3, 2018 | 05:49 PM
n2zcars's Avatar
Thx, I never thought to look there.... My local Midas said they would test it for me cheap if I pull the wheel well....They air my bicycle tires all the time when I ride to the grocery store. I am going to test intake for leaks tomorrow with both propane enrichment method and carb cleaner to try to decide if the intake as a whole needs replacement.
t.
