Command Secret Menus
Old Apr 21, 2002 | 01:01 PM
Silver_Lana's Avatar
Question Command Secret Menus
I have heard of some secret menus on the MB COMMAND system. I am curious as to what they are and how to get there. Thanks!
Old Apr 21, 2002 | 03:37 PM
Richard's Avatar
2004 SL55, 2015 A250d, 2016 GLC250d
Theres a bunch of menus that show s/w versions of all the control systems and whats connected on the fibre ring etc etc.
You can also view the diagnostic fault codes, clear them, and get put in a FM radio mode that shows the station name, the station frequency and the signal stregnth from 0-10
If you hold down the Mute, the 1 and the 3 buttons all together for about 5-10 seconds. If this doesnt work, select the auxiliary input mode first .. then do the above.
In the mode that shows you fault codes, holding Mute + 0 will clear the fault codes, Mute +1 and Mute +4 are two different fault lists - dunno what the differences are.
If you look on www.megacomm.de under telematik, mercedes, comand - you'll find some screenshots of the diagnostic screens.
Old Apr 23, 2002 | 10:44 AM
newMBz's Avatar
2002 C320 c2/c3/c4 & command
Richard,
Its a great info that you gave out here. Thanks. It works and I'm now understand more about my command system. If you have any more info on the Command, please post it here. Thanks !!
NewMBz
