W203 BREATHER PIPE REPLACEMENT
Hello everybody,
I need help!
i want to replace worn and leaking breather pipe (A 646 016 11 81) in my W203 c200 cdi of 2003 engine OM646.
the breather side of the pipe is easy to remove, however i am stuck in the other side.
i think if i remove the air filter housing it will be easy.
but I am not able to remove it, i am stuck since i didn't find the bolts to loose!!
Any help please with as much details as you can.
I need help!
Even easier to understand if you turn on captions, then auto translate, and set to english.
