W203 C240 4MATIC - trans mount DIY (not same as RWD)
Old Dec 15, 2018 | 06:02 PM
jvakos's Avatar
E63 SL55 996TT C5Z06
Does anyone have a w203 4MATIC DIY for the trans mount?
changing the trans mount its **NOT** the same process on 4MATIC that you see on all the 203 RWD trans mount DIY's here. I mistakenly got the w203 RWD trans mount from FCP Euro as their site doesnt specify 4MATIC vs RWD when you click the "does this part fit my car" so i thought it was correct.
So Here is the MB OEM trans mount part for w203 4MATICS = 2032400218 (also appears to be same part for e-class w211 and the 2005 and 2006 c230 sport)
This youtube video of a w211 4MATIC trans mount repair is what I assume the w203 4Matic will be similar to (
heres another w211 4matic write up on changing the trans mount : https://mbworld.org/forums/e-class-w...mount-diy.html
The part is 80 bucks from this MB OEM Parts site:
https://www.genuinemercedesparts.com...bC12Ni1nYXM%3D
It doesnt appear there is any aftermarket part option for the w203 4MATIC trans mount......
If anyone has a w203 4MATIC trans mount DIY it would be great to see that.... thanks
Old Dec 16, 2018 | 03:25 AM
tjts1's Avatar
C320
Everything is 5x more expensive on a 4matic.
Old Dec 16, 2018 | 10:48 AM
jvakos's Avatar
min realizing that!!!!! Love the 4matic still
Old Dec 22, 2018 | 12:08 PM
jvakos's Avatar
Got the corect trans mount for w203 4MATIC which as you see is very different from w203 RWD.
Will attempt to install it this weekend and do a DIY write up since I haven’t found one on the w203 board....seems pretty straight forward from what I saw on a w211 4matic trans replacement example.
