C230 Steering and Acceleration Questions
2004 C230
I have a 2004 C230 Sports Sedan and am curious if other owners have noticed similar issues.
First off compared to my Z4 the C230 is very tough to steer. Typically when turning a corner and accelerating in the Z I can let off the wheel and it will come back to straight as I exit the corner. With the Benz I physically have to turn the wheel back. The steering overall just feels very heavy.
Also, when accelerating there is a 2-3 second pause before the car gets going. I have had turbo cars and know about the lag involved with it but does a supercharger have the same? I did not notice this issue when I bought the car. I also wonder if since I live at 5,000 ft if that will make a difference.
Thanks,
Jeff
Thanks,
Jeff
Re: C230 Steering and Acceleration Questions
Steering system design, geometry and vehicle weight all have a hand in determining the overall feel of a steering system. Your altitude would have little effect on the performance of a modern fuel injected engine. While the air density would vary with changes in temperature, altitude and humidity the combustion requirements of the engine remain almost the same.
Re: Re: C230 Steering and Acceleration Questions
2004 C320
Don't both Turbos and Superchargers both use forced induction? The Turbo using exhaust gases to spin the turbine and the Supercharger using the belt to spin the turbine.
Even if the ambient air is rare (such as at high altitudes), a desired boost can still be achieved this way.
Supercharger, on the other hand, is an air pump driven by belt (because of this it is incorrect to call it a "turbine", BTW) and its speed is always fixed for any given engine RPM. So, although a supercharger does compress air, the resulting boost pressure still depends on the density of the ambient air to a much greater degree.
If you have an automatic and sense the delay when first starting off, that is a known issue with the MB tranny. It is actually designed that way for smoother take offs if I remember correctly.
The steering is heavy as it is supposed to be since it is a Sport Sedan. I actually like a vehicle that the steering wheel does not snap right back to center if I let off it, since I like smooth turning not abrupt centering and throwing the car all around. The W203 I think was the first to switch from recirc ball steering to rack and pinion, the W202 and W201 were both recirc ball if I remember right. So MB may have also made it stiffer so it was the same. If you want no steering feel go drive a Chevy Equinox, they have electronic steering with no feel what so ever!!!!
The steering on mine will self center as most RWD do, but it doesn't snap back. It is very controlable. Check you tire presure if the steering is too heavy. I run 32 front and 36 rear for every day use and 41 all around for autocrossing.
