Hello i need some help
It is almost impossible to decipher your message. Consider writing short sentences, and using punctuation.
- Is the starter always working?
- When the car starts, sometimes it shuts off as if you turned the key "off"?
- You had an error for camshaft sensor (on top of the engine), and you replaced the sensor? Did the error go away after that?
- Or was the error for the crankshaft sensor? (the sensor behind the engine, close to the transmission housing)
- Did you change the intake and exhaust cam sensors, and also the crankshaft sensor?
Search the forum for "start enable fuses"
and how does the fuel pressure look like before start, and after?
