Horn help!!
Old Jun 20, 2004 | 05:17 PM
JohnCL's Avatar
'01 C320 || '14 Honda Pilot EX-L
Horn help!!
My horn is not working on my C230 coupe. I pulled out the manual and that was no help, so I went to the fuse designation sheet in the passenger compartment fuse box and there is no listing for the horn. It started sometimes by going to one horn and then back to both, as you can surely tell when only one is working. I have checked all the wiring and it looks OK. Is this tied to something else in the car? If I am missing something totally obvious I apologize. Having no horn is starting to suck!! Any help will be appreciated.
Old Jun 20, 2004 | 08:03 PM
GixTom's Avatar
2004 C230K Sedan
Just curious, why not take it back to the dealer? I suppose its still under warranty?
Old Jun 20, 2004 | 08:10 PM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
if your car is under warranty. have you checked with the service dept. to see if they can help?
Old Jun 20, 2004 | 09:38 PM
JohnCL's Avatar
Warranty just ran out, maybe time for a new car!!
Old Jun 20, 2004 | 10:49 PM
HITMAN's Avatar
c230 kompressor
i was going down the road today and pressed the - button on the wheel and my horn honke and i didnt even know it was me then i press it again and it did it again!!
Old Jun 20, 2004 | 11:19 PM
thats happened to me as well about 4 or 5 times.
Old Jun 22, 2004 | 02:08 AM
BruNo's Avatar
07' ML350
just buy a new horn, u can buy either the "high" or "low" tone only, mine broke when my car was a month old. costs around $45, hella makes it for mb,but when u buy a hella outside...its cheap,but i dont think the tone is an exact match.
Old Jun 24, 2004 | 06:07 PM
JohnCL's Avatar
Got the new horns and it did not fix the problem. I have looked all over for the horn relay and cannot find it anywhere. Does anyone know which direction to point me in? I am assuming that the relay is the issue being that I cannot find a fuse for the horn either. Hopefully one of you can help. Thanks......
Old Jun 25, 2004 | 10:31 AM
JohnCL's Avatar
bump
Old Jun 26, 2004 | 02:24 PM
JohnCL's Avatar
OK, if anyone out there needs to check a fuse for the horn will will find it listed on the fuse documentation sheet as "FANFARE". Just another one of those German things to keep us guessing.
Old Jun 26, 2004 | 02:49 PM
o0omarko0o's Avatar
'01 320 Bril Sil/Ash
Thumbs up
get the horn that plays la cu caracha sound
Old Jun 27, 2004 | 08:16 PM
preyx's Avatar
'02 C230K Coupe
Don't forget the PA system so you can buzz other cars on the road. ^_^
