Brake upgrade
Old Feb 24, 2019 | 04:35 PM
rwb001's Avatar
2003 C230K
Brake upgrade
What options are there for brake upgrades on an 03 c230k?
Old Feb 24, 2019 | 04:42 PM
RedGray's Avatar
2005 C230K Sport Coupe
You're very lucky!
*I* just created a brand new site. Yes, this is a site that *I* am 100% solely responsible for.
I normally charge $20,000 USD for 1 second access.
But, for you, and only you, I'll give you free access for a whole day.
No need for thanks. I'll send the bill for the usage taxes (those aren't free) directly to you.
http://www.google.com/search?q=brake...on+an+03+c230k
Old Feb 24, 2019 | 04:44 PM
rwb001's Avatar
2003 C230K
This is the kind of stuff I'm more looking for.
https://ceika-store.com/products/cbk...BoCsTEQAvD_BwE
Always need options.
Old Feb 24, 2019 | 07:45 PM
tjts1's Avatar
C320
Are you going racing or are you just doing it for looks? Almost all MB brakes are interchangable so you have a lot of option if look at other MB models.
Originally Posted by RedGray
You're very lucky!
Do us all a favor and go **** yourself.
Old Feb 24, 2019 | 08:15 PM
rwb001's Avatar
2003 C230K
I just want some better bolt on brakes. I don't know what other benz models will work for this car.
Old Feb 24, 2019 | 08:19 PM
tjts1's Avatar
C320
C55,CLK55, E500 etc. They're all interchangable.
Old Feb 24, 2019 | 08:22 PM
rwb001's Avatar
2003 C230K
Thanks, I'll take a look at them.
Old Feb 24, 2019 | 10:27 PM
tjts1's Avatar
C320
https://imgur.com/a/Ij4G3
Old Feb 27, 2019 | 04:45 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Yikes! Brakes from China? Fuggetaboutit!
Just get the 4 pot AMG brakes like I have
and Akebono pads. They are sweet!
Not my wheels though....the one's pictured are 19's.
You need 17" wheels minimum, which are my stock rims.
http://installuniversity.com/mb/w203/w203/amgbrake.html
Old Feb 27, 2019 | 04:51 PM
rwb001's Avatar
2003 C230K
I ordered a set of E500 calipers. I'll see how well they work.
Old Feb 27, 2019 | 05:34 PM
tjts1's Avatar
C320
Youll need C36 rotors to work with those.
Old Feb 27, 2019 | 05:40 PM
tjts1's Avatar
C320
Youll need C36 rotors to work with those calipers. Check out Rock Auto
Old Feb 27, 2019 | 06:03 PM
rwb001's Avatar
2003 C230K
I already ordered those. I ordered for a 95, but I couldn't see a diff from 95-96-97.
Old Feb 28, 2019 | 02:15 AM
tjts1's Avatar
C320
My invoice says "AUTOSPECIALTY/KELSEY-HAYES EBR490 $ 9.31 each. When I opened the box the rotors were made by TRW in Germany. I chose this combination because they fit inside my 16" wheels with a 10mm spacer. If you have 17" wheel you might want to get larger late C230 brakes .
Old Feb 28, 2019 | 05:53 AM
rwb001's Avatar
2003 C230K
I've actually have 19" AMG knock off's. for wheels.
Old Feb 28, 2019 | 05:34 PM
mtnman82's Avatar
'16 E350, gone: '03 c230k
I put the mid-'04 brake set on my '03. Front and rear. Direct bolt-on. The mid-04 brake set are 4-piston front and 2 piston rear. You'll need the matching rotors too of course.. Great upgrade that makes a noticeable difference. I also put on the stainless steel brake lines which firms things up even more. There is a complication with the length of the caliper mounting arms. I can't recall but something like 330mm & 350mm and you'll need the matching rotors to accommodate. I bought a used set on this forum from someone who turned out to be a scammer and received one 330mm caliper and one 350mm caliper, which is how I know... The true mid-'04 c-class calipers are 330mm (or the ones with the shorter mounting arms). The ones with the longer mounting arms are E-class. As you will see, most everything will bolt up. Have fun!
Old Mar 4, 2019 | 07:41 PM
rwb001's Avatar
2003 C230K
My brake parts have all shown up, but it is currently 10 degrees outside and 30 degrees in my garage. I'll try and do this over the weekend when it supposedly warms up some.
