My 2002 C240 will turn on and after a few seconds will die. Any Help please !!
Old Feb 26, 2019 | 10:42 AM
Pimo1210's Avatar
Mercedes Benz c240 2002
Hello there, I was driving down the road and out of the sudden my car wasn’t responding to the accelerator. I pulled over to the side of the road and the car was idling very rough... then i was able to drive home but at 20 mph
I did got 2 codes : misfires in Cylinder 4 and 5 so I went ahead and checked all the spark plug wires and ignition coils and they seem to be working properly. Spark plugs are 4 months old.
I disconnected the Battery thinking that it will help, but now it has the same issue but now the computer does not show any faulty codes.
Now when I try to start the car the engine will run for a few seconded if it does and they will turn off.
Any help will be more than appreciated !!!
Old Feb 26, 2019 | 01:26 PM
tjts1's Avatar
C320
Check your fuel pressure at the rail with the engine running. Should've around 53psi. Symptoms are off a failing fuel pump.
