Anyone know W203 gear ratios?
Hi All,
I can't seem to find this info anywhere. I'm looking at an 05 230 Sport sedan and was wondering if anyone knew what the 5 ratios on the auto transmission and 6 ratios on the manual are? Also what is the ratio of the rear end? I'm trying to calculate comparitive engine speeds at different road speeds.
'01 E320 4Matic in White/Charcoal...
Re: Anyone know W203 gear ratios?
Originally posted by Nuvolari
Hi All,
Hi All,
I'd really like to know this as well (for a C320 SS). Mercedes treats technical info as though it was a national security issue. You'd think that, since they're going after BMW's lunch with these Sport Sedans, they'd wake up and realize some of us out here actually have a technical interest in these cars. They should also start offering a wider selection of sporty colors. Their current palate is fairly "mom & pop".
Originally posted by HITMAN
there is a thread about this if you would like to try our great search feature
GEAR RATIOS
HERE ARE THE RATIOS FOR THE AUTOMATIC
C320 5/A
1ST 3.95 2ND 2.42 3RD 1.49 4TH 1.00 5TH .83
SOME OTHER INFO
INFINITY G35
1ST 3.54 2ND 2.26 3RD 1.47 4TH 1.00 5TH .83
ACURA TL
1ST 2.56 2ND 1.55 3RD 1.02 4TH .66 5TH .48
IF WE HAD STOCK 260 HP AND TORQUE WE WOULD PULL BETTER NUMBERS THAN A G35 I BELEAVE AND IF THE TL DONSNT HAVE THE GEARS IN THE AUTO TO KEEP UP OFF THE LINE BUT SINCE IT REVS TO 6800 AND HAS LOW HIGHWAY GEARS EXPECT IT TO PULL ON YOU IN 3RD AND IF YOU GO FOR THE LONG RUN YOU HAVE A SHOT IN YOUR 4TH GEAR BECAUSE HIS IS TOO LOW... THE INFINITY TO BEAT IT YOU NEED TO MOD YOUR 320 I HAVE A POWERCHIP AND PULLIES MY CAR WILL BE BACK ON MONDAY FROM BEING REPAIRED AND I WILL LET YOU GUYS KNOW HOW I FAIR AGAINST BOTH CARS SINCE MY FRIENDS ARE WILLING TO HAVE A FRIENDLY SHOWDOWN.. MY FRIEND HAS A G35X AUTO 300IBS HEAVIER THAN THE NORMAL REAR WHEEL AND THE ACURA IS AN AUTO TOO..
C320 5/A
SOME OTHER INFO
INFINITY G35
ACURA TL
Re: GEAR RATIOS
C320 5/A
SOME OTHER INFO
INFINITY G35
ACURA TL
C320 5/A
SOME OTHER INFO
INFINITY G35
ACURA TL
