P0705 Transmission Range Sensor Error Question
Recently experienced transmission limp mode / CEL / semi-locked shifter issue on my 2005 C230 the other day. Currently the dashboard shows the transmission in D (drive) independent of the position of the shifter with "Sport" / "Comfort" indicator blank. ODB read P0705 (Transmission Range Sensor) error.
Common Causes:
-TCU (Not filled with oil, thank god)
-Shifter assembly position switch / PCB <--Likely candidate
My question:
Out of curiosity, I disconnected the shifter position wire harness and turned the key on. The dash STILL indicated the car was in "D" (Sport / Comfort indicator was blank).
Ben
