Audio 20 2005 Mercedes C180
C180 Kompressor Avantgarde 2005
Good Morning
I recently acquired a C180 Kompressor, 2005 Model, Avantgarde
I reside in South Africa
can someone please tell me what the below means
does it mean that my vehicle has been pre wired for an aux connection
or does it mean that there is an existing active aux connection
I have looked everywhere from the glove compartment to the centre console
and cannot find any aux input
regards
regards
2018 E300 4Matic, 2006 C180 Kompressor, 2007 S550 AMG Package
Yes, it does mean there is an Aux connection to the radio. Your car being a 2005 will not have the appropriate connection already installed in the glove box. You need to pull up the carpet on the passenger side of the car and find a white connector, you have to order the aux cable from the dealer to fit into this connector. After this you can install the aux wire through the glove box aux hole (which you have to punch out) on the left hand side.
May I suggest this video on how to install this connector.
another way to do it is to order the ipod integration kit from mb (or online) it has a 30pin connector that goes in place of that aux, the thing is that you can order a bluetooth to 30-pin adapter and add bluetooth to your car. beauty of this is that the ipod integration kit's 30-pin carries power for the BT so you dont need to install additional power. even better is that you can control your audio via the steering wheel controls and see the track/title on the dash display.
