HELP! Can't find my radio antenna....
Hi guys! Does anyone know where I can find my radio antenna? It's not on the trunk or roof. C280. 2007. 4matic. I have poor reception on some stations and my fuse #8 is ok.
Welcome! Please have a look at the diagram here, it might help you locate the antenna: https://www.mercedesbenzstarparts.co...enna-and-radio
Use Google, you will find that poor reception is fairly well documented. The antenna appears to be in the rear bumper. An amplifier is also in the system.
2005 C230 Sport Sedan-6 Speed Manual
I had a similar problem with poor radio reception. My problem appears to have been due to an oversight by the technician who replaced the rear window for a previous owner. The tech didn’t connect the antenna in the window to the antenna wiring in the car. You can read about my problem and the solution starting with the third post of this thread: https://mbworld.org/forums/c-class-w...0-revival.html
