How do i fix a bouncing door pin
Old May 22, 2019 | 04:21 PM
devtolu's Avatar
C230
My mechanic says i have to buy a new actuator for my C230 Kompressor 2004, can i repair it , because at times i think my car is locked but it may not be locked.
Old May 23, 2019 | 05:42 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
It's just a broken spring inside the actuator module. Buy the springs online and replace. Instructions are below.
Door spring fix
Old May 27, 2019 | 04:32 PM
jvakos's Avatar
E63 SL55 996TT C5Z06
Door spring fix
I found a super cheap and quick fix to the bouncing door pin lock, which cost you about two bucks and about two minutes of your time.
Take some 3M adhesive Velcro strips and cut off a eighth of an inch strip by 1 inch long and stick it to the door pin so that the Velcro is positioned right where the pin clears the door hole.
The additional friction from the Velcro to the side of the door hole is just enough pressure to keep the pin from bouncing.
Herss a couple pics - Mines been holding up for three years now on the same piece of Velcro !!
Good luck and hope that saves you a few bucks
Old May 27, 2019 | 05:19 PM
devtolu's Avatar
C230
I have repaired it by buying a used actuator for about $7 and paying someone about $8 to fix it.
Old May 27, 2019 | 05:21 PM
devtolu's Avatar
C230
