Car stalls
I needed a solution until I had the cash to check and fix the problem and I read somewhere that this will not happen if you add petrol. True: when the tank is full everything is fine but when it gets lower the problem appears again. The sad news is that now it happens between 50 and 65% fuel thus it will go worst soon. Lately I don’t like the cars rpm at very low speeds. If somebody can understand what’s going on please help!
p.S After reading that many issues are already posted and starting a new thread creates problems to the moderators I checked and read the threads about the fuel delivery system issues etc but I am not sure if my problem belongs there since the cars behavior changes depending on the tank level. If I violate any rules pls let me know @nd I will delete this and post under another thread! Thanks for your understanding
The fuel pump fuse is easy enough to visually check, and the fuel pump relay isn't known to go on these cars either.
