W203 electrical problem
Old Sep 15, 2019 | 06:43 PM
Huseein Zhour's Avatar
w203 avangard
Heloo there
i have a w203 2001 avangard.. my problem is weird a bit its maybe a transmisiom issue or electrical!!!
when i turn to the left and the car runing the transmission stick to the 3rd gear and no more tip tronic( just D) i turned of the car and on and evrey think return to normal until the next left turn and so on.
No probleme whith all right turn even with some speed
any idea???!!
Old Sep 19, 2019 | 01:47 PM
ronniecavs's Avatar
w203 cdi 200
Hi I had a problem with my car going in to limp mode usually on a roundabout which would clear if i restarted the engine my problem was the automatic transmission fluid was low and needed topping up
on a corner the fluid level would drop below the level sensor and cause limp mode
hope this helps
good luck
Ron
