New Trunk Closer Mod Coming Right Up!
Trunk opener/closer.....
How much for all the pieces? Any reprogramming needed? Does the standard key fob open the trunk remotely?
2015 E250D
I am waiting on the motor and wire harness. I will post everything when I get it in. Also, the dealer told me that there is not a single 209clk with trunk closer so this would make it harder to order parts. This option is from a 209 CLK.
2015 E250D
Originally Posted by accbenz
I definitely agree, you are lazy...BUT, I definitely LIKE the mod! How did you do it...and do I want to know how much $??
I estimated 800 in parts with harness, control module, switches, trim, motor, and latch. All parts are from a 209 CLK. Since we share a common chassis, it should be easy. Will have to wait for the motor to come in and see. There is mounting place on top of rear SAM if you can pull the lining a bit. There are 3 mounting points for the motor.
2004 C230k (SOLD), 2005 C230k (Lease ended), 2004 Carrera 4 Cab, 2007 530i
I have seen it on a S class. Stopped in front of me, popped its trunk then closed right back. I wonder if thats his way of saying "HI" ?!
'02 C230K Coupe
On a more serious note, how much were all the components? Also, is it that difficult of an install? I would guess that there are wires that need to be run and such. My mom's S500 came from the factory without that option, and maybe if it's not too expensive/difficult I may want to retrofit her car with a similar kit.
2015 E250D
The s class setup is different adn WAY more expensive becuase it's a hydraulic system becuase of door weight. I estimated mine at 800 bucks. Also, the wiring all trunk related.
If I get a CLK I am getting that option. Of course I need Keyless Go as well if I go that route. If the coupe does get discontinued the next one may have to be the CLK if I am in the Coupe mood.
Won't be for a year or two. Need a diferent new car next year and the wife loves the coupe too much to get rid of it yet. Just future thinking..... I would assume the CLK trunk is probably closest to the C CLass. Or is this option available in Euro Fashioned C's?
2008 c350 SG - 2004 c240 Wagon BS
I think I need that on my wifes 203 wagon.
Then she can shut up her girlfriend with the stinkin' Chrysler Pacifica.
