A/C blows hot air
W203 (2007), W120 (1962)
A/C blows hot air
My W 203 C180 compressor blows hot air when a/c is switched on.
But it blows cold if temp is set at minimum (18^C).
Any setting at above 18^C, immediately blows hot air. No loss of freon.
Any suggestions welcome, Thanks.
MBworld Guru
If you have a sunroof, try opening it. If that restored the AC operation, then it's a bad sensor in the overhead control panel. Search the forum for "thermistor" (also try the W209 as it's the same unit).
