Timing chain replacement
Old Nov 5, 2019 | 04:37 AM
Saethorkristinn's Avatar
C240 w203
Are you supposed to replace your timing chain, i got the m112 engine and the last owner tild me that you never have to replace it but i dont really trust that, my car is driven 186.xxx km
Old Nov 5, 2019 | 07:54 AM
tjts1's Avatar
C320
Why do you want to replace the timing chain on an m112? What's wrong with it?
Old Nov 5, 2019 | 02:31 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
No, the timing chain in an M112 engine should outlast the rest of the car. Now, the M271 (I4 engine) uses a single-row chain and it has been known to break or stretch.
Old Nov 6, 2019 | 11:23 AM
wanderlust360's Avatar
2003 C230 Sedan Manual
And there is no easy way to check if the timing chain on a M271 engine has stretched, correct? I understand from reading other threads that a rattling noise on start-up might be the only indication of something going bad. I am guessing removing the valve cover and tugging on the chain would not be a reliable method of checking.
I have close to 200k on mine with the original chain. The chain pre-tensioner broke off a while back, but apparently did not cause any consequential damage at the time. Has anyone gotten recent quotes for replacing the chain?
Old Nov 6, 2019 | 12:26 PM
C240 w203
Theres nothing wrong with it, i was just curious about it
Old Nov 6, 2019 | 12:27 PM
tjts1's Avatar
C320
The M112 timing chain is very reliable and should last indefinitely if you do regular oil changes.
Old Nov 6, 2019 | 11:20 PM
RedGray's Avatar
2005 C230K Sport Coupe
https://mbworld.org/forums/mercedes-...tensioner.html
