Timing chain and Tensioner
Many mechanical failures very roughly have a "bathtub" like failure probability.
After some time and/or usage, the probability of failure increases.
More details:
I do not know the failure rate for the timing chain in your engine. However, it seems like it might be a common failure point.
The timing chain in my 2005 C230's engine, an M271, is a POS joke! A bicycle chain looks massive and beefy compared to the POS timing chain in an M271 engine. A number of people have had the timing chain fail between ~~70K and 100K miles. If/When the POS timing chain fails in an M271 engine, then the engine is garbage!
Which brings up a point.
And one of my favorite questions.
"Do you feel lucky punk!"
In other words, some people may have had timing chain failures before 100K miles. Some people have gone over 100K miles, and haven't had any timing chain failures.
That type of failure/use is common in real life with many mechanical parts.
It's up to each person to decide if the cost of preventive maintenance replacement is worth it to them, verses if the part fails in "x miles or months".
For people like me, for a cross-country trip, *I* will take the reliability of my 30+ year old Mustang with ~200K miles verses your car or any car/vehicle (new or used), because of the preventive maintenance I do on the car.
I, and many other people, know very well the likely failure points and the reliability for the parts for my Fox Mustang.
Fwiw, *I* am replacing the timing chain in my C230's M271 engine every 50K miles. I'm also using a real MB timing chain bought directly from a dealer. Yes, I know that IWIS makes the timing chain for MB. The MB timing chain from MB even has an IWIS-marked packet for the link.
From the IWIS and MB-original timing chains I bought, they do look to be the same. And, I have a decent amount of professional experience looking at mechanical parts and tolerances.However, even if the timing chains where made on the same exact machinery, by the same exact people, that does not mean that the timing chains are "equal". See the NASA document for more information on part testing/verification procedures by the manufactures. The MB part might go through additional test and/or have more samples tested. Or, it might not. Considering the cost difference (~$150), and the consequences of a timing chain failure (imho - a worthless trashed engine), *I* am not willing to take that chance.
So, when picking replacement parts for your engine/car, once again, ....
Below are a number of reference links:
Mechanical Failure Mechanisms and Reliability
March 2, 2013
Reliability Curves
http://www.opsalacarte.com/reliabili...d-reliability/
Mechanical failure can occur at any point in a product life cycle. These can be divided into infant mortality, constant failure rate, and wear out.
Mechanical Failure of Materials - Springer.com
pdf format
www.springer.com/cda/content/document/cda_downloaddocument/9789814560375-c2.pdf?SGWID=0-0-45-1433632-p175459859
Note: Imho, below is a very good thesis paper that goes over a lot of the issues involved in producing a reliable product:
Scale-up of a High-Technology Manufacturing Startup:
Improving Product Reliability Through Systematic Failure Analysis and Accelerated Life Testing by All Shabbir
Submitted to the Department of Mechanical Engineering in partial fulfillment of the requirements for the degree of
Master of Engineering in Manufacturing at the
Massachusetts Institute of Technology - September 2015
(Note: New Valence Robotics is a 3D Printer manufacturing startup founded by four MIT students.)
https://dspace.mit.edu/bitstream/han...856068-MIT.pdf
Assessing Product Reliability - Information Technology Laboratory
pdf format
www.itl.nist.gov/div898/handbook/toolaids/pff/apr.pdf
Reliability Training - NASA Technical Reports Server (NTRS)
pdf format
https://ntrs.nasa.gov/archive/nasa/c...9920023212.pdf
Characteristics of the Weibull Distribution - weibull.com
http://www.weibull.com/hotwire/issue14/relbasics14.htm
Univ of Mass - Weibull Handout
pdf format
http://www.ecs.umass.edu/mie/faculty...%20handout.pdf
Drexel University
Department of Mechanical Engineering & Mechanics
ENGINEERING RELIABILITY and FAILURE MODELS
MEM361 Lecture3
pdf format
http://www.pages.drexel.edu/~hgk22/c...1-Lecture3.pdf
Disclosure: I have degrees in Engineering, along with various ties to MIT.
Back in seventies the timing chain replacement before or at 100000 km is a must.
