NEED HELP....just installed C32 AMG brake kit
1 Post
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
I am experiencing a bit of shaking at the steering wheel and petals. Before and after my brakes were installed, I experienced a bit of shaking at 80 mph.....Now that I just added spacers on there, Its shaking at 60 MPH..... WTF..... I do not know what to do.....
I'd first make sure that nothing's loose, then take it to a tire place that I trusted, to make sure that the wheels are weighted properly - sounds to me that the spacers are exaggerating a condition that already existed.
After that, next up would be the alignment, then the suspension parts, then the driver.
But I'm guessing that the wheels are off-balance right now; one of mine was, for some reason, several months ago; shop trued them up, and no more vibrations. Good luck.
The True OG Modded out W203
Originally Posted by MARK CUMMINS
Make sure the SPACERS are Hub Centric type..otherwise you WILL Have Problems..also get the wheels rebalanced
:werd: just get some hub centric spacers, I had the same problem a few years ago too.
1 Post
I paid 50 bucks from H and R....i am assuming those aren't hub centric......hmmmm.....i dun know...
W203 C240
Dude i just got my brake kit...im debating on whether i should do it myself or take it to a shop....good luck with your prob..sounds more like a rim prob
2002 C230 Coupe Black/Charcoal C5 C7 Auto
having spacers in the front especially is not a very good idea. If you must maybe 3-5mm ones and only if you MUST for clearance sake. i would check for wheel balance though and maybe alignment. i just got mine and havent noticed anything diff other than better braking (feel more solid)
2001 ML320 E, 2003 C230K Sport Sedan
Got a lot of miles on the tires? Maybe it's time for a new set? You did say you were having problems before the brake change...right?
Ed.
Ed.
1 Post
thanks guys for you suggestion......I will try to figure out whats wrong....i'll keep you guys posted....
