Newbie with c230 and c280 key swap
Old Feb 14, 2020 | 08:31 AM
ponchonutty's Avatar
C230
So my son ditched his c230. I was able to buy a complete running c280 parts car. The c230 has only 1 key. The c280 has 2 keys. Could I swap ????? And end up with 2 working keys?
Old Feb 15, 2020 | 08:35 AM
jaGTAR KAHLON's Avatar
2004 c230k
No
The EIS (electronic ignition switch), cluster and most other modules are “married” to the VIN. You technically could if you changed over every single module associated and in your case engine.
You could however send out your ignition switch with key to get a cloned key, how much and where I’m not sure though
Old Feb 15, 2020 | 04:55 PM
C230
Interesting. I was under the impression on these the ignition, steering wheel module, ECU, and cluster are all that need to be matched. I see on EBay that’s usually all they list to be sold as a “kit”. Just trying to be 100% sure on this. Thanks for your input.
