CL203 headlight lens
Hello all, I have a 2005 Sportcoupe, the headlight cover needs to be replaced on both sides. I thought I just had to polish them, I later realized the are dirty inside too.
I can easily find the W203 sedan lens cover, are these compatible with the coupe?
Thanks!
Thanks!
2005 C230 Sport Sedan-6 Speed Manual
No- I replaced the lenses on my sedan. When I was searching for the lenses I remember reading that the lights on the coupes and sedans are different.
The W203 coupe and sedan headlights are definitely different.
Be careful, many places/sellers advertise that the headlights fit all "C230 cars" - they do not.
Also, the same is true for just about anything body related, even with roof racks. The coupe is wider. Why? Ask MB, not me. :-)
Good Luck!
Good Luck!
2003 C230K Coupe Orion Blue
Coupe and sedan are different.
The really dumb thing is that the dealer does not sell the lenses separately as the headlights come as a completed assembly from the supplier. Not sure who makes the 2005+ lenses. For the pre-facelift vehicle, Hella makes both the halogens and bi-xenon versions. You might be able to get somewhere by contacting a local authorized distributor.
The lens covers can be removed with a bit of heat from either a toaster oven or hair dryer. If they're dirty, just do a meticulous cleaning job. If they're yellow or scratched too badly, you're probably looking at a wrecker.
2002 C230K, 2013 BMW 328, 2015 BMW X5
