New here and needing some help
Old Aug 5, 2020 | 04:50 PM
mwider's Avatar
2007 c280
I have a 2007 c230 with a 722.9 and I need to know how to relearn the range sensor and will I have to have a star tool to do that or is it possible using a FVDI? any help will be greatly appreciated. Thanks
Old Aug 6, 2020 | 06:03 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
I'm not familiar with this.
Can you explain a little?
What and why does the range sensor need to be relearned?
Old Aug 7, 2020 | 07:54 AM
mwider's Avatar
2007 c280
I had a new valve body and conductor plate installed and coded, but on the autel it says that the range sensor needs to be relearned or signal is implausible? After checking around on google I have read that you need a star tool to relearn the range sensor, but I'm not sure. Any ideas would be helpful. thanks.
Old Aug 7, 2020 | 01:46 PM
Russell Ormerod's Avatar
not a merc
Best is to use xentry. And yes range selector needs to be learnt. If FVDI has the option then try it if you don't have access to xentry
Old Aug 8, 2020 | 08:32 AM
mwider's Avatar
2007 c280
Thanks for the help. I really appreciate it.
