W203 climate fault
W203 climate fault
Hello there. I bought a W203 sw 220cdi vehicle. The air conditioner does not work. I took it to a mechanic where I was. Control unit is said to be defective and flaps are defective. I bought a unit and went to an electrician. He told me to leave the vehicle. He repaired the car the next day, and he took a lot of money from me. Air conditioning was working. The next day it didn't work again. The mechanic said the problem might be from sams. I had to go to another city. An electrician there looked and cleared the faults and said nothing. Interestingly, it worked again. Then do not restart. I went to the mb service. Star connected there. It was said that the problem was flaps. However, in my own opinion, there is no point in working ac with flaps. The compressor works when energized from outside. Freon level is a little low as the air conditioner is not working. 450gr. Can you please help? Air 40 degrees. Also another little mechanic told me I have c1022 engine and CAN communication error. Engine smokes.
You have so many stories, I dont know which one to believe. Take the car to someone who works on MB cars and has the diagnostics, else you will fall into the FUYAA hole and get no where.
I went to the mb authorized service. He told me that the weather was getting cooler and I would go out by opening a window. There is a flap failure, so he said it doesn't work.
