Swapped Valeo to Bosch alternators, and light stays on.
Secondly, did you connect the negative terminal (ground) wire AFTER connecting the positive terminal to the battery? My understanding is that not doing so fries the front SAM and possibly other units, and is a common (rookie) mistake when working on these cars. Usually such a frying causes way more errors than just the alternator, but once again, just throwing it out there.
This morning after doing some EGR service (irrelevant to this situation) I measured the battery giving out 16V while running on a multimeter, even though the computer/cluster reads 13.5-14.0 volts with the alternator light coming on. I checked the battery on a 99 ML430 W163 while running, and I got an identical reading, but there is no battery or alternator light coming on in that car. So I feel as if to just ignore the light and check the battery every other day or so to see if the voltage goes way beyond 16V.
