C230K, engine stalled going up drive way
Hi,
My wife's C230K engine stalled when going up friend's drive way. This really concerns us. Prior to this, when going over speed bump, the engine rpm will drop really low-normal-low-normal. I told my wife it's OK because you confuse the car when you step on the gas to go over the speed bump then immediately step on the brake. But when she stalled on the drive way, we have to take it back to the dealer.
engine stalled - update engine code
hid too low - replace sender unit
left rear door hard to close - replace weather strip
We went to Rusnak, Arcadia, CA. When we pick up the car, there were still grease inside the rear left door.
We had to ask the guy that pull up our car to clean it again. And the car is not clean after they washed it. My local car wash can do a better job. Could it be our car is not a S500?
Just wanted to post this, in case someone has this similar sympton.
