LH door mirror stopped heating
So, the driver's side door mirror in my 2007 doesn't heat, while the passenger's side door mirror works fine. Where is the mirror heater plug for me to check it?
I searched and didn't find anything, so feel free to delete the thread if it has been discussed before.
Gorilla Jones (11-06-2020)
OM646 (11-07-2020)
OBC shows no errors. Is it supposed to throw a code for the heated mirrors? I only found out it wasn't working properly when after a drive, i found out there was still a lot of condensation in one mirror but not the other
EDIT: typo
EDIT: typo
What ecu did you communicate with when you looked for errors? You need to be checking the door control module faults. A generic obd tool is useless for this problem
I meant OBC, the driver info display, like nothing shows there when I start the car. Guess i'll have to find someone with the correct diagnostic tool to check the door control module
