Is it okay to do this???
Old Aug 25, 2004 | 11:18 AM
Oil Change's Avatar
I want to put my C coupe on nutral, then step on the gas till the RPM reach 6000 then shift to drive...
the car is auto.
Old Aug 25, 2004 | 11:22 AM
Brunelleschi's Avatar
In the market
I wouldn't...but that is me
Old Aug 25, 2004 | 11:26 AM
wingless's Avatar
Debadged 6-Speed '05 C320 Sports Coupe
Sounds whacked to me, but go for it and report the results.
CitronC230K_03's Avatar
2003 Citron Green C230KMT
there is a Rev limiter you can only rev it to like 3000 - 3500 while the car is in neutral.
Old Aug 25, 2004 | 11:30 AM
Oil Change's Avatar
No... I can rev till the red line on neutral. It will stop at 3000 if the car is on Drive and u have one foot on the brake and the other one on the gas.
Old Aug 25, 2004 | 11:55 AM
jo17jC230's Avatar
2008 C300 Sport
I wouldnt do it either
Old Aug 25, 2004 | 12:03 PM
JohnCL's Avatar
'01 C320 || '14 Honda Pilot EX-L
the car is auto.
What is the point?
Old Aug 25, 2004 | 12:06 PM
Oil Change's Avatar
Originally Posted by johncl
What is the point?
the rear wheel will spin, making sound and stuff...
Old Aug 25, 2004 | 12:10 PM
JohnCL's Avatar
Buy a Mustang or some other muscle car.
What is the draw to spinning the wheels these days?
Old Aug 25, 2004 | 12:18 PM
Jkw's Avatar
Jkw
2004.5 C 230
If you want to do "Neutral Drops", Buy an old Chevy & Beat on it till the trany cryies for mercey!
Jkw
Old Aug 25, 2004 | 12:41 PM
Oil Change's Avatar
I'm saving money to get 350Z :p
maybe in a year or two i'll be able to get one! But I'm afraid after two years I'll feel too old for doing stuff like that!
Old Aug 25, 2004 | 12:43 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
Keep doing it, and you'll get some even more interesting sound from the tranny.
Old Aug 25, 2004 | 12:44 PM
Oil Change's Avatar
btw I've done it only once on a car I was renting abroad... and that was accidently
but I like the result!
Old Aug 25, 2004 | 12:58 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
you'll be saving up for a new tranny if you do it...and as far as I know it, the rev limiter kicks in @ 3800-3900 RPM's when in Park or Neutral...
Old Aug 25, 2004 | 01:01 PM
Oil Change's Avatar
I always rev on park and neutral, and it always reach the red line...
is that bad?
Old Aug 25, 2004 | 01:31 PM
dave_88's Avatar
hah, dont' do that, my friend was stupid enough to that that in his step-dad's old 300SL and then the tranny went, needed a new tranny and a new set of tires...
Old Aug 25, 2004 | 02:09 PM
mctwin2kman's Avatar
Do it and see if MB warranties the tranny for you after they look at the ECU to see what caused it! These cars do have data recorders so the manufacturer can see what happened! As well as the fact that the tranny will go back to MB in Germany for a thourough looking at to find the problem and it is not too hard to figure out what happened when the tranny is in all sorts of pieces inside it! I have no problem spinning my tires if I want without needing to drop the clutch from a high RPM range. Just starting out normal and flooring it will smoke mine just fine! Don't be a moron and ruin a perfectly good tranny to see some smoke. Turn off ESP floor it with the brakes depressed, then release them and the tires should spin somewhat, if you really wanted to smoke them you should have got a standard shift! The auto tranny and drive-by-wire throttle will stop a power brake due to design, as it is not needed in everyday driving ever!
Old Aug 25, 2004 | 02:35 PM
prodigy1387's Avatar
C320 Coupe
i wouldn't suggest doing that.....if it's bad to shift into neutral while driving, i highly doubt it's not just as bad to shift into drive while flooring it in neutral haha.
also, i dunno about your car, but my car has a rev limiter so i can't rev beyond around 4000 rpms in neutral, as other people were indicating as well.
i'd say: if you really want to spin your tires, i think you can wait a year for your 350z and not risk damaging your current benz. or, even better, buy a higher output benz or AMG vehicle...at least to me, i rather drive a faster benz than a 350z.
Old Aug 25, 2004 | 03:18 PM
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
Exclamation Do It !! Do It !!
the car is auto.
I say do it, and let me know what parts you want to sell, when your car is totally destroyed.
Do you have factory Bi-Xenons ?
Clear fog lamps ?
Power seats ?
Old Aug 25, 2004 | 03:41 PM
Sauceboy01's Avatar
Blimp
not a good idea unless you want to shred apart your tranny gears.
I learned my lesson on my 1991 190E (first car).. Did redline Drive drops.. Shredded the gears.. Spent that whole summer working my *** off to pay for the tranny repairs. My parents almost killed me.. I was 16..
-Danny
Old Aug 25, 2004 | 03:46 PM
well my car is a stick, and im pretty sure if its in neutral i can't rev it to red line. then again i dont sit there and red line my car so i really wouldnt know.
Old Aug 25, 2004 | 03:56 PM
revstriker's Avatar
K Car
Where I grew up, this is called a "Neutral Drop". It's a very quick way to ruin a transmission. If you REALLY want to spin the tires, then just hold the break down just enough to hold the car still while flooring the gas (I'm not even sure if this will work in an MB). Again, I wouldn't recommend doing either of these things as they will take their toll on your car. But if you don't care, then go for it.....
As far as the rev limiter, I'm not sure what location "OIL CHANGE" is in, but if he is outside the US, the rev limiter might not be the same as ours.
Old Aug 25, 2004 | 04:31 PM
even doing that in a loaner ispretty messedup. i do drive loaners a little harder than i drive my own but i dont, do things like red lining them, ruining thrannies or anythinglike that. whatever!
Old Aug 25, 2004 | 06:00 PM
preyx's Avatar
'02 C230K Coupe
I've tried it once, rev to 4k RPM, then drop the tranny. ESP caught it and I didn't really go anywhere. Once the revs dropped down to about 1k the car took off normally. Even the magazines that reviewed this car said that the best times on the auto were obtained just by straight flooring it off the line. If you just want to do smoky burnouts, just do the "stand on brake AND gas" trick, that'll give you more than enough tire-burning satisfaction. N-drops are stupid (I admit it), but even more so they do jack squat in our cars.
PS - What model/year car do you have? I know that the previous-gen trannies (without the "tip-tronic") were a lot less restrictive on this sort of activity. My friend was telling me how you could initiate shift-lock drifts on an automatic SLK by dropping the shifter from D to 2 while going at speed.
Old Aug 25, 2004 | 06:11 PM
Oil Change's Avatar
well, first... I'm not thinking of doing the "Neutral Drop" any more :p
I only thought about it cuz i found its impossible to rev the car while I'm stepping on the brake on D... which is something most people in this topic told me to do to get the result that I want.
I have a 2002 C coupe compressor by the way.
