220 cdi Mopf Dpf delete
I'm faced with the dilemma of whether to delete the Dpf and I don't know if I would also delete the Egr, as I'm of the opinion that the Egr would let it perform its function. The car has driven 205,000 km.
Opinions are welcome
I've egr vac lines plugged on a 25 year old petrol turbo , this cured a cruising kangaroo effect .
And an 18 year old turbo diesel on 190K , this gave me more turbo spool as exhaust gasses aren't being diverted + several other benefits .
DPF clogged is only an effect. The cause is a malfunction on engine.
Even if you delete DPF, EGR, etc the problem will remain as the main cause of malfunction is still there.
And yes, the role of EGR is too much important ...imagine as EGR role is the same but on reverse as turbocharger ( beside the cooling function - as the EGT can't cool...........without EGR help)
Turbocharger fill your combustion chamber with more quantity of Oxygen ( more O2 can handle more fuel, so more power...) and EGR fill your combustion chamber with less O2 ( for the same volume) and less O2 can handle less fuel, less fuel means good consumption, less pollution, smooth driving at low speeds, etc
I've found the egr delete / off / disable to be worth a few mpg and that's over 4 cars with it done .
The S14 was smoother at low cruising speeds after the vac line disable .
The recirculated hot sooty inert exhaust gasses causes even more soot through more incomplete combustion of fuel molecules , hot egr gasses can even hole plastic / composite inlet manifold , more soot to carbon up VNT turbos , soot to combine with normally occurring crank case oil vapour creating an evil gunk that coats the inlet system causing things to break and less efficientcy .
Soot is abrasive , gets in your oil and causes wear .
If you think an engine should breathe it's own excrement you must be mad . We have an air filter for an engine to breathe cool , clean , filtered air and that is what it should only breathe .
The egr is the devil !
From long time ago, MB use EGR gas cooler and what is more important is that if your engine runs smooth, the exhaust gas is also clean.
When engine needs power, the EGR is always closed, so...from where abrasive soot?
Also, deleting the EGR is ilegal. Annual or registration tax is based on CO2 emissions, declared with EGR on.
Yes modern MB , despite an egr cooler these hot gasses still can hole a composite inlet manifold .
Diesel compression combustion produces more soot than petrol and the egr causes more soot to be produced .
The only way you will get clean egr gasses are those who have recirculation post dpf !!
Which very few car makes have .
For city drive, when Engine did not produce heat or soot, use high pressure EGR with cooling circuit.
This way, the combustion chamber is filled with air with much less oxygen, this permits a less quantity of fuel ( due to stoichiometry) to be used.
Is exact the reverse of turbo, in slow drive it simulated a half a engine ( use a 2L Engine with 1L O2/fuel ratio), so less consumption with low gas temp and of course without NOx.
In partial request, like low speed highway driving, the high pressure EGR is always closed and the second EGR begin to make the air/oxygen ratios convenient.
The second EGR is after the DPF and use clean gases.
And when full potential is needed, all EGR's is closed, this way all exhaust energy can be used by the turbo, that compress more oxygen in the same volume of the combustion chamber...that simulates a double capacity Engine.
Those are not my thoughts... every manufacturers use this simple and effective solution.
Also, forget about soot into intake manifold, on actual models...of course only if you use correct oils, filters and especially the Service Procedures.
Apparently, the vehicle has Dpf installed. What is the actual difference between Dpf Euro 4 and Euro 6 for example?
But there is huge differences between the engines and management strategies.
Newer generation, besides better power and smoothness, consumption or longer service intervals, produce a far less smoke or dirt.
Of course, the NOx part is that where worries is focused now, but again on MB, this is different than rest of the brand's.
Don't forget, there is only 2 types of cars in this world... Mercedes and the rest!
