Electric seat issue
Old Feb 13, 2021 | 09:28 AM
Serkku's Avatar
MB cl55 ///AMG, MB s203
Electric seat issue
Hi! I have this issue that Electric seat just gets stuck suddently. Sometimes it unglitches by itself and works completely normally for many months. So when you move it forward it moves 1cm and stops. If you keep pressing it wont move anymore. If you tap fast it moves each time by 1cm, so you can move it somehow. Then the hight ajustement works normally. Back doesnt lean at all. When using memorh it does move normally, except lean doesnt work. So when using memory everything works fine, but when ujusting manhally only 1cm by a time. When tapping lean nothing happens also
Old Feb 14, 2021 | 02:56 AM
Russell Ormerod's Avatar
not a merc
Check for a possible coin that fell into the rails. Its possible you have a faulty hall sensor too. First check fault codes
