Side mirrors not responding
Old Mar 14, 2021 | 07:42 PM
kingjones4's Avatar
2006 Mercedes benz c230 sport
Can someone tell me all the possibilities that can make my side mirrors stop working? My turn signal lights are working just fine, my mirrors aren't responsive. I press the buttons to control them and they don't even move in the slightest way.
Old May 16, 2021 | 06:13 AM
Jocahox's Avatar
2007 230 sport
Buy new mirrors
Don’t attempt the you tube videos about taking it apart and fixing it it’s a pain and you can never get it beck to normal
Old May 16, 2021 | 12:59 PM
kingjones4's Avatar
thanks for the response, since I've posted this thread I have learned so much more about my side mirrors not working. it's the motors that stopped working.
Old May 17, 2021 | 10:31 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
That's not true at all. The module can indeed be taken apart like anything else. Just be careful not to break the clips.
Did both mirrors stop moving, or is it just 1 side?
I used to have a problem with the L mirror not moving every once in a while. Turns out that the rubber "button" (underneath the plastic button you push) for the R mirror (selector button) occasionally got stuck in the "pushed in" position, so when I selected the L mirror, the car got confused because it thought both mirror selection buttons were being pushed down at the same time. A drop of silicone lube fixed the problem.
These switch assemblies aren't known for failing electrically at all. I'm wondering if both your L and R selector buttons are stuck.
The other possibility off the top of my head is a blown fuse.
Old May 18, 2021 | 02:02 PM
Donald McPherso's Avatar
180 Elegance
Another fault could be the wire inside the plastic sheath broken. My indicator sopped working and I cut out the bad bit and re-soldered a new bit on.
Old May 23, 2021 | 03:59 AM
kingjones4's Avatar
yes, occasionally the buttons do get stuck from time to time. I switched the motors out on both of them and nothing happening. I do have a message talking about the right mirror.
Old May 23, 2021 | 04:00 AM
kingjones4's Avatar
my wires are perfect on both of them
Old May 23, 2021 | 04:03 AM
kingjones4's Avatar
so you mean wd-40 as the silicone lube?
Old May 23, 2021 | 08:38 AM
slammer111's Avatar
Don't use WD-40. It's known for degrading rubber parts. Just pick up a can of silicone spray lube at the local hardware store for a few bucks.
WD-40 is really only meant to displace water (WD = Water Displacement).
Old May 23, 2021 | 02:00 PM
kingjones4's Avatar
thanks for the insight. I definitely was about to try it out, not any more
Old Jun 9, 2021 | 02:46 PM
kingjones4's Avatar
I haven't bought the silicone spray yet, but I wanted to know what fuse should I change to get the mirrors to turn, MIRROR ADJUSTMENT FUNCTION (21,22,63)
Old Jun 9, 2021 | 05:43 PM
slammer111's Avatar
Some are probably tied to the memory package. If in doubt, replace all 3. Just swap fuses with an equivalent one in the same box.
Old Jul 22, 2021 | 04:22 PM
kingjones4's Avatar
I found out what it was. I used my scan tool mbII, and it told me that the left and right control module was the problem.
Old Jul 22, 2021 | 11:12 PM
slammer111's Avatar
So both modules were damaged?
