C230 Gas Gauge not correct
Old Apr 17, 2021 | 11:47 PM
Tanker01's Avatar
AMG C230 Kompressor Sport Hatch
So My C230 Hatchback gas gauge all of a sudden does not read correctly. The odometer is still correct but the gauge is super far off. When the tank is empty the gauge is only just under half a tank. Is there any way to reset the gauge or something? I have been just using the odometer as a gas gauge and refilling it when I hit 300mi.
Old Apr 18, 2021 | 03:53 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
The gauge is controlled by a floating sensor attached to the fuel pump. Wondering if the one in your car is somehow malfunctioning.
Old Apr 23, 2021 | 02:01 PM
Russell Ormerod's Avatar
not a merc
What work was done before the issue? Pump replaced? Rear sam replaced? There is no calibration that can be done on cluster
Old Apr 24, 2021 | 12:19 PM
tjts1's Avatar
C320
There are 2 fuel level sending units in the saddle tank. Left and right. The computer uses input from both to calculate fuel volume. You need a scan tool that can show you which of the two sending units is malfunctioning.
