ABS and Kompressor valve problems
Old Apr 25, 2021 | 03:39 AM
Mpower94's Avatar
w203 coupe 2002' c230 kompressor m111.963 197hp
Hello, greetings from Bulgaria. Please excuse me for mine probably bad English. The history of the car is quite long, it was mine a few years ago. It went through several people and now I get it at a very low price. The car has a rather complicated problem for the mechanics here. Here are the problems; The main problem is that the compressor valve refuses to work, the valve itself is working just does not receive a signal from somewhere. The SAM module was changed, the engine ecu was also changed, they were synchronized but now I can't synchronize the valve. And at the moment it is not even possible to connect the ecu with star diagnostic. The second problem (which I think is related to the first) is that ABS does not work, does not count kilometers, does not count speed or fuel. many times we have read the car, except ABS MODULE there was no other problems.
Now if i buy ecu ,sam module and the key, because i think that mechanics jus cant do the job properly.Will the car start? The question i what i need to start the car without any kind of synchronization or something else.
p.p I almost forgot, wen i start the car it gives around 10 beeps.
The car is 2002 c230 coupe m111.963 197hp
