Loose steering after replacing combonation switch
Old Apr 26, 2021 | 10:30 PM
djlink771's Avatar
C230 Kompressor 2004
Hi, I own a 2004 c230 Kompressor and have recently replaced the combination switch in the vehicle. Since the repair, the steering wheel has about 2" of play in it not centered. During the repair, when taking off the center bolt, the steering wheel was held down enough to where it got damaged. How should I go about correcting the steering wheel play and center the steering wheel?
Old Apr 27, 2021 | 02:13 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Are you talking about the loose metal collar? If the plastic shroud (along with the cruise and turn signal stalks) can rotate, the link has the solution.
Old Apr 27, 2021 | 09:25 AM
djlink771's Avatar
Sort of, its not the plastic shroud that covers the combonation switch, it is the actual steering wheel. When the wheels are centered and straight, the steering wheel is turned 45 degrees right and is not as tight as it use to be. When turning it lightly back and forth, it has alot of play and slack to it.
Old Apr 28, 2021 | 11:00 AM
slammer111's Avatar
I'm assuming the steering wheel is properly attached to the shaft. Was this 45 degree problem there before you took apart the system? If everything was reinstalled properly, there is no reason for the steering wheel to be in a different position. Did you mark the shaft before removing the steering wheel?
The steering wheel is attached to the shaft by a spline. It is pretty much impossible to damage these teeth, short of using a grinder.
Start following the mechanical parts down into the footwell and through the firewall into the steering rack, while having a buddy jiggle the wheel. There are only so many parts from end to end.
Hopefully it's not the steering rack, or you're looking at an expensive replacement. It's probably something on the steering wheel end though, if this problem suddenly appeared right after the signal stalk replacement.
