Where to put jack-stands under the W203?
Old Sep 6, 2004 | 05:27 PM
kokketiel's Avatar
'01 ML430, '03 C320 Coupe MT, '14 GL450
Where do you guys put jack stands when rotating wheels, etc? I use the jack points to jack up the car, but then I would like to put jack stands under the car for safety. I browsed the owners manual, but did not get any suggestions there.
Any advice?
Thanks!
Old Sep 6, 2004 | 06:15 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Frame
Old Sep 6, 2004 | 06:43 PM
W Cole's Avatar
makes your daughter horny
I've looked through both the manual and the forums and really couldnt find a clear answer.
So what i do is put them right under the rubber mounts, what I do is take the adjustable height part of my jacks off so they are as short as possible, and then put a strong piece of pine between the jack stands and the rubber mounts so the mounts do not get damaged.
Old Sep 6, 2004 | 06:55 PM
Buellwinkle's Avatar
I use the center jack points (rubber block just under the motor or the rear differential housing) and then use the side rubber jack points for the safety jack stands.
Old Sep 6, 2004 | 08:19 PM
KWiK's Avatar
2002 C230 : 2007 C230
Like Buell said, use the center jack points...
Attached Thumbnails Where to put jack-stands under the W203?-w203_front_center_jack_point_01.jpg   Where to put jack-stands under the W203?-w203_front_center_jack_point_02.jpg
Old Sep 6, 2004 | 08:58 PM
Sauceboy01's Avatar
Blimp
i put mine directly on the front bumper and the sideskirts..
They always end up breaking though.. why are our cars made so cheap!
Old Sep 7, 2004 | 08:32 PM
kokketiel's Avatar
Thanks for all the replies! You guys are the best...
Old Aug 13, 2009 | 11:51 AM
Malsor13's Avatar
2001 c240
so for the rear you put it on the differential. what if you just wanted to put up one side? can you raise it on the control arm and then put the stands on the jack points?
Old Aug 13, 2009 | 07:23 PM
Emin's Avatar
2010 C300, 2012 Mustang
The front spots should be behind front tires and the rear spot should be in front of the rear tires
Old Aug 13, 2009 | 09:10 PM
skittles's Avatar
Moped
WOW THERE! revivedfrom 2004! lol!
Old Aug 13, 2009 | 10:28 PM
d1no's Avatar
05 c230k 6spd
^^ at least he searched lol
Old Aug 14, 2009 | 11:35 AM
amanonfire's Avatar
W203
That's a good question for the rear, would be interested in what others do. My jack isn't low enough to get to the rear diff (my car is slammed) so I have to drive up on wood blocks before I can get a jack under.
If there's somewhere else I could put the jack stands and still use the rear rubber mounts for the jack, that would be great.
Old Jun 29, 2011 | 05:30 AM
c240DUDE's Avatar
2002 C240 (SOLD), 2006 E350
My front driver side is missing the rubber attachment. Is there any other place to put the jack stands without damaging the car?
Also, would a 2-ton floor jack be sufficient enough to lift up the car in the front using the center jack point?
Old Jun 29, 2011 | 08:14 AM
tommy's Avatar
2004 Civic Si. FWD for the Win!
Yes, it is - I have the 2-ton Harbor Freight special, and it works on that center piece just fine.
Why not just get a replacement rubber piece for the part that's missing, though?
Old Jan 7, 2012 | 04:52 AM
Peydidy's Avatar
C63 AMG
I am super confused how to put my car on stands, I want to have it on 2 stand so I can have both front wheels up at one time or both the back wheels up. I tried using the center jack points but the rubber thing just ended up braking and my car fell (luckily I wasn't under the car when it happened) any help?
Old Jan 7, 2012 | 12:49 PM
ncmudbug's Avatar
2005 C230K, 2019 Honda CR-V, '74 Lotus Europa
Use the center jack point as a jack point. Behind the front wheels and in front of the rear wheels are the jack points for the jack in your trunk that MB gives you with the car. There are pictures of people using stands on them but I imagine it depends on the saddle of your stands whether that will work for you. You can get jack stand pads that fit in the jack points on the side of your car that are safe here: http://reverselogic.us/ReverseLogicL...Pad_Tools.html
There are probably other solutions, but this is what I use. You'll see a gizmo on that reverselogic page that is for using your floor jack on the side jack points. That doesn't work for me because my floor jack is too high. Besides, it is much more often that I want to lift the entire front or rear of the car than just one wheel (at least in my garage). I use the my floor jack with the standard jack point in the center of the front of the car or on the diff.
Hope that helps.
Old May 2, 2012 | 04:28 AM
Peydidy's Avatar
C63 AMG
Sorry for bumping an old thread again but I need to grind my inner fender again so I need to raise my rear and put it on jack stands again. Before I was using the rubber mounts to raise the car and doing each side at a time but the rubber mounts broke. It was mentioned above about a rear jack point but I can't find one, could someone tell me exactly were it is? thanks in advanced
Old May 2, 2012 | 04:38 AM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Diff
Old May 2, 2012 | 05:48 AM
Blackbradpitt's Avatar
2002 C320
Just bought the same one today. Only $25, can't complain at that price
Old May 2, 2012 | 04:31 PM
Peydidy's Avatar
C63 AMG
Originally Posted by C230 Sport Coup
Diff
Diff?
Old May 2, 2012 | 04:56 PM
tommy's Avatar
Rear differential - that big metal cluster in the center between the wheels. I've been using it to change my rims out for a decade now without messing anything up yet.
Old May 2, 2012 | 06:44 PM
MBfinatic's Avatar
e36 318i, 2004 sti
Mercedes, so headhurt
Old May 2, 2012 | 07:43 PM
04mbc230's Avatar
2006 C230 Sedan
Answer to this question about jackstand or jack. DON'T
There is a reason why it has those rubber points, so that you can't jack it up yourself. It's meant that you call roadside assistant or bring it to the dealership. There are $$$$ to be made by these people and for you to DIY means taking money out of their mouth. Also, they think that if you can drive a Mercedes, you must have $$$$ shoot out of every orifices.
I tried jacking up my car just to change tires. I thought, mind as well use my 2 ton jack instead, but nope, it doesn't work. Notice the rubber points start bending and all, thought it won't hold much longer and since I don't want to risk damaging the skirts, I gave up. I end up going to the back trunk and used the Mercedes design jack. Looks werid, but it works. Took a little more time since it's not the 2 ton heavy duty jack, but it did it's job.
I remember seeing an adapter for sale somewhere that you can use with your 2 ton jack. I also suppose you can use this adapter for your floor jacks as well.
oh well..
Old May 3, 2012 | 04:24 AM
JFarhanbod's Avatar
2003 C230K Sedan
oh well..
idk what your talking about theres the front jacking point for the front and the diff in the back just jack it up and put jack stands on the side. put the middle sloped part of the jackstand on one of the points of the rubber pad on each corner of the car. car goes up and you get your work done.
Old May 3, 2012 | 08:27 AM
ncmudbug's Avatar
Those rubber jack points really require something else to use for jack stands or a jack. I got aluminum blocks that fit in the jack points for my jack stands.
http://reverselogic.us/ReverseLogicL...1_Entry_1.html
