Question for all DC/VA/MD owner's or for others that sees occasion snow falls.
Old Sep 16, 2004 | 08:56 AM
mb4now's Avatar
2005 c230 SS Auto/Sunroof/Entertainment/Lighting/Power Seat w/memory/Heated Seat/Split 60/40 Sold
I have a question on winter driving in the DC Metro area.
We all know the amount of snow that we get in the area isn't that much compare to some of our neighbor in the upper region.
My questions are:
How have you been getting around in your C's in the past year during the winter time?
Does a set of dedicate snow tire is really needed?
or
What have you been using in the past?
I have not owned any rear wheel drive car since I moved from into the area for the past 7 years. Actually, I have but it always stayed park when snow. So, I really never even thought of buying any type of winter tire for my current or past cars.
Thanks much for your input.
Old Sep 16, 2004 | 09:28 AM
moa4r's Avatar
S4
my e-class was basically useless anyime it snowed a little last winter; definately going to try out winter tires this time around; I got stuck for 45 mins @ the top of my neighborhood because my car couldn't get up a 15 degree hill; HTH
Old Sep 16, 2004 | 09:34 AM
SteveS's Avatar
2003 C230 Kompressor Sedan
I spent a lot of time in the DC area and further north last winter. I live in the Atlanta area, so the Performance tires that come with the car are fine for down here. Since I knew I was going north at least three times last winter, I swapped out my Pilot sports for Continental Sport Extreme Contact. Even in upwards of six inches of snow, I did not encounter any problems that had made me wish I had snow tires instead.
The Continentals are a good balance of performance for the dry days, wet handling for those rainy, gee I wish this was snow, days, and the normal volume of snow the DC area gets. Anything beyond about six inches, you probably don't want to be driving the C anyway.
The only problem I have run into the the Conti's is they have a tendency to give you a flat spot thump for about the first 5 minutes of driving that goes away after some heat gets into the tires.
You definately do NOT want to keep the Michelin Pilot Sports on during frozen winter weather. They turn into a hockey puck at about 35-40 degrees, with almost no adhesion.
I am pretty sure I will be flamed for recommending the Conti's but I have had nothing but excellent experience with them.
Old Sep 16, 2004 | 01:13 PM
nicedeboy's Avatar
Missing my beloved Benz
When the first snow flake hites, get the chains.
Old Sep 16, 2004 | 01:22 PM
UStifosi's Avatar
C230K
I drove mine sparingly as I have a Subaru SVX for crappy days. If you have the Sport pkg with the Pilot Sports then forget it. As everyone else is saying, buy another set of snows...and if you are going to go that route I recommend Blizzaks. Go to TireRack.com for more info.
