SRS Clearing question
Old Sep 23, 2021 | 10:36 PM
scott414's Avatar
2002 w203, c240
Have an ISoft MBII and trying to clear my stored SRS codes, unable to clear with MBII. Do I need to take to dealership just to clear these codes?
thanks in advance
Old Sep 24, 2021 | 01:45 AM
Russell Ormerod's Avatar
not a merc
Cheap tool won't clear srs. Use DAS
Old Sep 24, 2021 | 12:03 PM
scott414's Avatar
2002 w203, c240
Thought the MBii was able to clear codes. These are saved, not current. Ideas anyone else?
Old Sep 24, 2021 | 04:01 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Look like the MB II should be able to clear SRS codes, assuming you have the genuine article.
The video shows the procedure for the Sprinter but you get the idea. No idea if this works for saved codes. When you say the codes aren't current, do you mean the codes have been cleared (and therefore no SRS light) but the car is showing a history of the SRS codes?
Old Sep 24, 2021 | 06:03 PM
scott414's Avatar
2002 w203, c240
all only 1 was current and stored, I fixed that yesterday and status changed to stored, Should be able to clear as other stored codes in past....
Old Sep 25, 2021 | 01:02 AM
not a merc
No tool will clear a current code! Saved or stored or whatever you want to call it can be cleared but only with the correct commands. Because it works on a sprinter doesn't mean it will work on your car. Totally different ecu variant. Use the proper tools and you will have no problems.
Old Sep 25, 2021 | 07:54 AM
DFWdude's Avatar
2016 E350 Sport
The MBII or MBIII will indeed clear stored and current codes. I use the MBIII model.
The iCarsoft tools designed for the entire Mercedes family include software for both Sprinter and MB sedans, etc.
Stop being a tool snob.
Old Sep 25, 2021 | 07:57 AM
DFWdude's Avatar
2016 E350 Sport
thanks in advance
Be sure to power cycle the car OFF after erasing codes, removing the iCarsoft beforehand.. The video above outlines the procedure.
Sometimes, you will need to let the car sit for 2-4 hours for it to power down completely.
Old Sep 25, 2021 | 09:16 AM
not a merc
LOL.. Good luck!
Old Sep 25, 2021 | 09:58 AM
scott414's Avatar
2002 w203, c240
Im trying to clear STORED codes, I dont have anything in SRS that is current, Unfortunately, my MBii wont clear for some reason. Yes, it has been registered and updated,
Old Sep 25, 2021 | 11:11 AM
DFWdude's Avatar
2016 E350 Sport
My MBIII has cleared Stored codes. Sometimes it takes a couple tries.
Old Sep 25, 2021 | 03:26 PM
not a merc
Why a couple of tries? Either it works or it doesn't ?
Old Sep 25, 2021 | 06:20 PM
DFWdude's Avatar
2016 E350 Sport
Some components take a longer power off cycle than others.
Old Sep 25, 2021 | 07:32 PM
scott414's Avatar
2002 w203, c240
well, still with these codes unsucesfully cleared, Its been a day of fun
Old Sep 26, 2021 | 01:43 AM
not a merc
Mate you wasting your time! I work on mercedes every day. There is no such thing as clear codes a few times. No such thing as wait hours or even minutes to reset codes. Find someone with a genuine tool and your problem will be solved. Those cheap scan tools can cause more problems than they fix. I have seen it myself.
