Cylinder head gasket question
Old Sep 27, 2021 | 07:31 PM
mcc23's Avatar
C240
The front most part of the cylinder head gasket that connects to the timing case has gotten slightly bent and I can not seem to get the timing cover on the dowels without removing that bent part. I was thinking of cutting off the portion that's in the way and use a healthy amount of the MB sealant instead. Will this be sufficient for a seal? TIA
Old Sep 28, 2021 | 04:12 AM
Russell Ormerod's Avatar
not a merc
Good luck.. I would say new head gasket needed
Old Sep 28, 2021 | 05:52 AM
112233's Avatar
w203cl
Is it where head, block and cover meet? It will leak anyway after a while, I would try it with RTV.
Old Sep 28, 2021 | 07:39 AM
mcc23's Avatar
C240
Yea. So you don't think the RTV will be enough to prevent leaking?
Old Sep 28, 2021 | 07:42 AM
mcc23's Avatar
C240
Ugh not what I wanted to hear. But thank you for the feedback!
Old Sep 28, 2021 | 08:01 AM
not a merc
You can only try but if it leaks then the only way is to remove cyl head
Old Sep 29, 2021 | 09:35 AM
112233's Avatar
w203cl
Its not a big deal, a minor leak is quite common there
