P0020 rattle on cold start! 05 C230K
Greetings, Guys I need your help again! I have a P0020 code. I have new sensors, cam magnet sensors, and cam gears, No oil in the wiring! I swapped Cam Sensors no change. Could it be the Cam Shaft gear bolts? How to check? There is a little rattle when cold starting, The timing is good, it drives good.
2005 C230K 4cyl manual 6sp
Thanks for Reading!
Thanks for Reading!
2005 c230 Kompressor sedan 1.8L w203
P0020 after installing camshaft magnets
My w203 is running fine but getting this code. I think I got it either after changing head gasket or changing camshaft magnets. We’re you able to find a solution for p0020?
Changing camshaft magnets can cause this code..
Have you tried putting the original intake cam magnet back in to see if it will clear the code?..
