Car not starting
After parking it last night, I tried starting my car today and it cranks but will not start. It sounds like it cranks empty (no fuel going to engine) and the fuel pump does not run when I turn the ignition to 2nd position or while cranking.
Warning Triangle sign, LIM and DTR lights are on.
Things I tried:
- Checked fuel pump fuse and relay, both good
- Checked voltage at fuel pump, 5 pin connector but 3 pins only on pump, no voltage present
- Tried resetting the ECU
- Checked all fuses and relays
I searched online and people say it could be the rear SAM, how do I check it?
