pano roof stuck at 4" open even w/using a tool
Old Dec 27, 2021 | 11:40 AM
nlinesk8s's Avatar
C230 coupe
I know there are a ton of threads out there about the panoramic roof and replacing or reinforcing the motor. This isn't about that.
Sunroof is stuck; just makes the gear slipping sound when I operate the switch.
I was able to manually with a tool open the sunroof to about four inches. Any more than that and no amount of trying to help it seems to make any difference. The passenger side seems to be stuck.
If I can't open this I certainly can't lubricate the tracks.
The video from Mercedes showing how to remove the sunroof panel begins with: "open the roof fully." That's not happening.
I guess I could try again with an assistant pulling mightily on the passenger side, but before I go there I thought I'd ask if anyone has dealt with this and has suggestions?
Old Dec 28, 2021 | 11:53 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
I thought the problem with the sunroof gearbox typically involves one of the gears slipping out of position (caused by the gearbox casing warping) such that the teeth don't engage? Hence the threads about adding the washer to force the gear into position.
Old Jan 2, 2022 | 01:48 PM
nlinesk8s's Avatar
C230 coupe
I found a nice thread on adding a stiffener plate for the motor housing to address the typical gear issue at:
https://mbworld.org/forums/c-class-w...-thread-2.html
Unfortunately I dont' think that's my issue. in the comments of the thread there are documents on removing the roof and the likely failure causes.
Unfortunately, this doesn't look like an afternoon fix. Even if I can get the sunroof off and access the tracks, I think it's likely there is damage that will require ordering expensive parts (assuming they are even available). So I think I'll wait until Spring on this one.
Old Aug 29, 2025 | 11:41 AM
Lukya's Avatar
Cla
Solution to my sunroof problem
I had a problem with the sunroof of my car and I solved it by buying these modified parts.
Old Aug 31, 2025 | 06:52 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Push hard on the sunroof while attempting to close it.
Once you are successful, disconnect the motor and fuggetabout the sunroof.
Any further attemtps to open and you will regret it.
